M1009 antenna
reallybigboat
Oak Point, Texas
If you are looking for what I have on my M1009, it is the AS-1729 / VRC antenna. The base and attached spring bolt right on to the vehicle mounts.
I believe the NSN is 5985-00-985-9024 for the AS-1729.
I have seen other bases that might work, but the AS-1729 was a direct bolt on for my M1009.
Good luck!
Wile E. Coyote
75
Lynden WA
MX-6707 Antenna Matching Unit (AMU) usually, which with the whips previously mentioned makes up AS-1729. Lots on Ebay regularly - some new. You can also use AS-3900/ AS-3900A which is the ant. system for the SINCGARS radios - all bolt in the same hole.
Other antenna systems were used depending on what radios were in the M1009, but that's the common setup.
