M1009 Brake Issue
helobravo
south east louisiana
(I looked at the TM's and didn't find anything specific for my problem.)
The front drivers side brake started dragging and heated up until I could smell it.
I wasn't to far from the house so I let it cool down and then drove it home. It did not drag on the way home and I did use the brakes a few times on the way.
When I tried to brake to turn into driveway, my pedal went to the floor with no brake action.
I had to use the emergency brake to slow down and park.
Since then I have put 10-15 miles on it and everything works great.....
I have no idea what the deal is and wish it would've stayed broken so I could fix it.
Any ideas are appreciated.
Chaski
56
Burney/CA
The front caliper could be sticking because of corrosion, or bad hoses (can act as a check valve of sorts). Tear it apart and see what you find. I'd replace all brake components (all mine are less than 5 years old), after all they are all most likely 30+ years old.
You can get a caliper hot enough that fluid can boil. Once that happens the pedal will travel to the floor, or at least a lot further than normal. After it cools down it may act normal again. There are a ton of variables and who knows what brake fluid concoction others may have used in it over the years.
Please don't ignore your rig "talking" to you. Two weeks ago another forum I visit a member totaled a classic car, after he had had intermittent throttle linkage problems. The car "talked" to the owner, with interment sticking throttle problems. Owner ended up totaling the car and putting his wife in the hospital.
Rvitko
Austin tx
I had this happen and I have new hoses and calipers, in my case the guide pin just had some crud on it and needed to be cleaned and greased so the pads could retract smoothly. Check the guide pins.
