M1009 brake proportional valve wire
saltypoptart
corpus christi/TX
Hello all,
I had a question Regarding the brake proportional Valve. The previous owner of my M1009 removed the plug used for the brake proportional valve(photo). So my proportional valve is not hooked up.
I looked up some threads and the tm and was able to trace back and find the truck side plug near the coolant overflow bottle, so i have the wire and plug for that bracket.
I guess my question is, is the bracket and plug even neceassy? Or can i just splice the wire straight onto the proportion valve?
Please let me know if I need to clarify with afditional pictures.
thanks
deank
542
Inverness, Florida
Electrically it does not matter if the bracket is not there. Just secure the wire in several locations as it is a long run and may move with airflow into places it does not belong.
saltypoptart
corpus christi/TX
Thank you for your reply.
That bracket appears to have a spade to attach the wires. My question is do I need the bracket with spade connections for the valve light to work correctly? Please see photos.
i have the truck side wire. The wire coming off of the valve is broken off.
Can I just splice the connections together? Or does this bracket with the spades serve another purpose for each wire end?
