M1009 CUCV Top Seal
Mainsail
1,539
Puget Sound, WA
If you're doing the seals around the top, here's a cheater:
Classic Parts. Here are the four seals:
01-817 (1976-91) Blazer - Body Side Seal - Le1 $29.95
01-818 (1976-91) Blazer - Body Side Seal - Ri1 $29.95
01-813 (1976-91) Blazer - Upper Header Seal -1 $34.95
01-814 (1976-91) Blazer - Upper Header Seal -1 $29.95
There's some sort of spray glue that you use as well but I don't remember the name right now. Nasty stuff- makes a mess.​
665
Madison Alabama
I replaced all of the seals on my M1009. You'll need two side seals, inner cab seal and outer cab seal. They do glue in with weather strip adhesive. Was not that difficult once you get the cap off and get all the old seal and adhesive off.
PM me if you have any questions. I bought a full seal kit when I did mine.
