M1009 Door tag
covert
iowa
I need to know what the tag on the drivers door says. Mine is faded and part of it is missing. This info will help me in trying to get the thing title and plates. Thanks in advance. Its sticker type of affair
1,171
Here's one I found with a Google image search for "cucv door tag".
1,171
Again, Google image search for "CUCV VIN tag"
This tag is located on the door jamb, below the striker bolt.
1,171
You can also find this info in the basic operators manual (-10TM).
I have never seen the vintag on a door of a CUCV. They have always been under the door striker bolt, on the jamb.
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
That tag in door jamb is not the one for DMV the one on the dash is what they need OEM MFG VIN Plate and has factory rivet that was install at Truck & Bus Flint Mi.
the door jamb tag is to show that was Military spec Equipment with Restation NO and M?????? status of said equipment.
covert
iowa
So I take it all you guy who have an M1009, do not have a sticker type tag on the driver side door (its on the edge, cant see it when the door is closed) about lower window height?
On the civilian blazers this sticker says it meets federal safety standards. Now mine has the sticker but like I said if too faded to read. So I'm trying to find out from others what this sticker says. Thanks again.
Evil Dr. Porkchop
269
Colchester, VT
ok, i know what your talking about now, but don't have a picture right now
covert
iowa
M1031cmt thanks. thats the sticker i am talking about. could you post what it says? Thats the info I need.
Evil Dr. Porkchop
269
Colchester, VT
the bottoms section states:
This vehicle conforms to all applicable fede-
ral motor vehicle safety standards in effect
on the date of manufacture shown above
Firejareen
Rural Retreat VA
Iowa must be a strange bird. That sticker has nothing on it for the purposes of titling. It only states the tire sizes and some general info about the truck. The vin is the only thing you should need for titling a CUCV. And maybe the weight. It is a Chevrolet Blazer or 1-ton Pickup. It has a 6.2l diesel motor and drives on four tires. Thats it.
covert
iowa
The Iowa DOT WILL NOT title and plate a vehical that does not meet the federal moter vehical safty standards. It sucks good thing I titled my Deuse's before the "CRACK DOWN". Its enough to make me consider moving.
Thanks for your help I now know beond a dought it does in fact meet the federal standards.
1,171
Should have just asked that, we would have told you they do.
