M1009 Engine Problem
RECON 101
kanab,ut
M1009 Engine Problem ?
My "84 M1009 completely lost power climbing a steep hill I coasted back down Engine was barely running then stalled I restarted it, the engine raced then stumbled I shut it down restarted, run poorly with no power from then on. What I found so far oil in intake manifold all the way into the heads, fuel filter base leaking. starts ok has a slight miss blue grey smoke at idle throttle it up and black smoke and stumbles misses real bad. Has anyone else had same issues? is it the IP ??? I know CDR Valve is bad and fuel filter base needs to be replaced. feed back needed.
