Jkiszka
- -1
- 1
- Colonia, NJ
HISTORY:
When I first got my M1009 it didn't start up because of a broken resistor and bad glow plugs so I replaced all of the glow plugs and removed the resistor and set it to where it can only send 12v. The truck started after all this and drove for about a few hours before shutting off. Now I had a new issue to find. With the original fuel filter set-up in my M1009 the engine would start up after A LOT of priming and cranking, but would then die after a few minutes and noticed there was air in it when I tried to prime it again. So, I did some research and found out the original housing is prone to air leaks. I bypassed the original filter and placed an inline filter to make sure the air was getting into the housing. With the inline filter, the truck would start up with no issues and ran. After about 1 week and a 1/2 I decided to place on a new filter set-up.
CURRENT ISSUES:
I had replaced the filter housing and filter (due to an air leak) to a spin-on filter set up with a 3-micron filter w/ water separator by WIX. After I primed the filter the first time, the engine fired right up. It ran for about 8-10 minutes strong and then the engine shut off. When I checked the new spin-on filter, the filter was half empty. Also, when I opened the valve to bleed it pressurized air came out. Being that the air was pressurized, I know there is no air leaks. Now I have to crack the injector lines to let the air out, then prime it to start it. When I start it, it only runs for a few minutes. Does anyone know what's going on here?![shrugs :shrugs: :shrugs:](https://www.steelsoldiers.com/images/smilies/confused1.gif)
Thanks!
![IMG_2195.jpg IMG_2195.jpg](https://www.steelsoldiers.com/data/attachments/437/437906-e9290b8ca62c2961d4f34a15b2569eef.jpg)
View attachment IMG_2193.MOV
CURRENT ISSUES:
Thanks!
![IMG_2194.jpg IMG_2194.jpg](https://www.steelsoldiers.com/data/attachments/437/437907-8af680d22a4aa603c64fe683bc25410a.jpg)
