M1009 Fuel lift pump to fuel filter hard line replacement
placek59
11
SE Nebraska
Hello All,
New to the diesel and CUCV world here but have been reading a lot and learning a lot too! I purchased the Blazer about a month ago. I knew it was hard to start and had a fuel leak among other things that a 40 year old snow plow truck would have, but I thought it was a good deal so I nabbed it! I drove it home about 8 miles from where I purchased it with out any issues, other than the fuel leak was pretty bad by the time I got home.
I thought it was a return line and the previous "owner" didn't know much about it (bought from a small private school and the maintenance man I dealt with was relatively new to the school and they got a newer plow truck so got rid of the blazer). Finally got around to working on it over the weekend and cleaned up the mouse nests under the intake (on windage tray??) and found the leak to be coming from the hard line that goes from lift pump/fuel pump up to the filter on the firewall.
Is this a common issue?
Can anyone point me in the correct direction to order a new hardline? I cannot find anything available and may not be using the correct terms for search functions. A part number if still available would be helpful.
Would the 6.5 and 6.2 share the same tube?
Thanks for any help,
P59
WWRD99
1,925
York Pa
Dang!! Having that steel line rust out is not a usual problem. Pretty sure it's a 3/8 line you can buy and bend up to fit. If not the civi is about thr same if you can find one of those. Not sure about 6.5 being the same. I've had the rubber hose chewed up for that line a few times.
Sent from my SM-S906U using Tapatalk
87cr250r
2,131
Rodeo, Ca
I would hose it. Use SAE J30R10 hose with FKM tube and cover and it will outlast everything.
placek59
11
SE Nebraska
I don't think it rusted out, although it could have, I thought it may have been rubbing/vibrating against the head or valve cover for quite a few years and eventually worn through.
I had thought about using hose and that way I could be lazy and not have to remove the intake.
Would cutting the hard line a few inches from the leak and using a hose clamp with the fuel hose cause any problems? Approx how much pressure is in that fuel line? Is there a better or proper way to do that shortcut?
Is the hard line that goes into the lift pump a flared line? A type of tapered pipe thread? Any advice is appreciated
Edit: after cleaning up the mouse nest better and doing some more investigating, a pinhole had rusted through and was spitting a tiny stream of fuel
cucvrus
10,501
Jonestown Pennsylvania
It is a flared line. Are you in a big hurry for this line? I maybe have one. Maybe. I do if I can find it. I have had them rattle to pieces before from not being secure in the clamps to the block up front.
87cr250r
2,131
Rodeo, Ca
These hoses see 5-10 psi. It will hold with a clamp on the tube but if you want a barb you can flare the tube and use one of these.
I do not recommend worm drive clamps for small diameters. Use a pinch clamp. They're inexpensive and so is the install tool.
placek59
11
SE Nebraska
I don't think I'll be in a big hurry if I can get by with the crimp and flexible hose for awhile. I think it would be something I will want to fix in the future though. I want to get the fuel leak fixed so I can give it a better shakedown, put some miles on it, and see how far down the rabbit hole this project may take us and our wallet.
placek59
11
SE Nebraska
Thanks for your help, I got it replaced with some Gates 30r9 fuel hose for now and the proper sized crimp clamp. Couldn't find any 30r10 locally and the local diesel truck shop said they don't stock any fuel hose and just use whatever CarQuest has in stock. Hope that can last me for awhile. Now I seem to have a glow plug relay issue as the light on the dash doesn't come on and I can't get it to fire up. I'll do some reading and start a new thread if needed.
87cr250r
2,131
Rodeo, Ca
J30R9 is good. It has a Viton tube with chlorinated polyethylene cover. The R10 hose has a Viton cover. CPE is often used for electrical wire insulation and has good durability under hood.
vanaisa
407
Tallinn, Estonia
here, post nr 14 helps you with glow plug diagnosis:
