m1009 fuel question. i think
lussks
santa ana ,california
Been working on this project. Got it running, runs good strong motor... But i have a problem if i drive it for a while shut it off when I go to start it within couple minutes I have push the gas pedal to het her going again all the help will be helpful thanks
chevyCUCV
Massachusetts
Air leaking into the system, Too slow of a cranking speed, Worn IP
Put a clear fuel line on the return line from the IP and look for bubbles.
Does it start easy first time of the day with no pedal and minimal cranking?
lussks
I can drive it 2mins or 2 hrs its the same I have to hold the gas pedal 1/4 throttle to start up. If i just crank it over it won't start.
Wats the best way to check for air leaks in the fuel system. Thanks
