M1009 gauge problems
MT4222
Plymouth/MI
Hi I have a m1009 with original size tires and the speedometer reads 10 mph faster than what I am doing. The fuel gauge is also stuck at 1/2 tank .. Any ideas on how to fix these would be appreciated. Thank you.
Barrman
1,730
Giddings, Texas
Is it a constant 10 mph over or just fast at speed? All the time too fast and I would think somebody changed out the drive or driven gear for the cable in the tease. Sometimes too fast and jumping then I would suspect a bad cable or casing causing it to wind up. It is a 85 mph speedo, not a 110 speedo?
The -20 manual has a great section on how to diagnose electrical gauge issues. Pretty much it can be the gauge, the wiring at the back of the gauge panel, the sensor wire, the connection at the sender, the sender or the sender ground.
MT4222
Plymouth/MI
It is a constant 10 mph over and it came directly from government liquidation so I don't know who would have changed the gear. Any ideas why the fuel gauge is stuck at 1/2 ? Thank you
cucv1833
Lake Charles, LA
Really need to check the TM -20 manual. Do the testing as per the TM.
It should help pin point the problem.
Mine just started showing half full after I cleaned up the instrument cluster. But first I think you should check the ground under the dash by the E-Brake then the ground on the Frame for sending unit. , clean the fuel gauge terminals, Make sure the main plug into the instument cluster is clean and Tight.
Speedo- On the M-1009 theres supposed to be a adapter that the Speedo cable goes to on the transfer case. Theres no adapter on the M-1008. If the adapter is removed on yours that may be the promlem. SO many differnt options. Cable, gauge, adapter, Speedo gears. I just changed my speedo cause it was jumping and now it works great.
I tried to clean it but desroyed it. :-(
Do some testing and searching then report back.
