tgtaylor64
- 4
- 18
- Florence, SC
Can someone help me troubleshoot this? Stock M1009, 24 VDC setup, going through resistor bank. Multimeter ground to rear of driver side alternator, positive to top of glow plug relay - reading 24.5 VDC, everything off. Upon startup, engine cold, I read 7.5 VDC at this point while the glow plugs are heating. Why only 7.5 VDC? If I connect the positive lead to the bottom lug (to the GPs), I get about the same. I just replaced my relay thinking it was pitted or fouled. The new one is reading the same! By the way, I get the same response whether I feed the top lug from the resistor bank or the 12 VDC diamond (of course, I have only 12.6 VDC or so on the top lug before I cycle the GPs, then it too drops. What is happening? Where am I loosing 5 or so volts? All connections are clean, shiny, and greased.
