m1009 headlight problems
shnuzz
Bought the truck a few days ago and all the lights worked fine until yesterday. checked and changed most of the fuses but I think it has something to do with the blackout system since it's only the headlights, turn signals, brake lights, and emergency lights that don't work (all of which can be controlled by the blackout system, right?) any advice on what I should look at or where to get an electrical schematic would be appreciated.
mangus580
283
Western NY
first, check and make sure the blackout switch is set right.... ;-)
I think there is a relay that handles this. Let me dig up the TM that has the schematic in it, and I will post it to the tech manual section.
MakuaKane
Thanks for that tech manual Magnus. I let someone borrow my M1009 and then the lights, all lights, stopped working. No service lights or blackout. I figured it had something to do with that darn relay. With having the manual in pdf format I was able to search for a picture of where the relay was located. Will post the results when I figure it out. Maybe someone else will have the same problem.
aja458
lehigh valley pa
headlight problems-m1008
the m1008 i just bought, lights arent working. it doesnt matter where the blackout light switch is set. any fuse,relay or something else i should check? no turn signals,headlights brake lights.thanks for any help. great site
mangus580
283
Western NY
RE: headlight problems-m1008
The switch on teh right needs to be in the top position. To do this, you need to pull out on the handle of the switch and flip it up.
dilvoy
25
San Francisco, Ca.
My brother is having the same problem with his M1009. It had no lights at all, even no BO lights since he got it surplus. I chacked all the fuses and they are all good. I think I'll chack the connection at the fusable links and see If I find any problems there.
1,824
Just a little drift from topic here. When I got my last M1009 it looking like George the Butcher had a training day on the wiring harness. I printed out the schematic from the -20 PDF and took it to Office Depot. They enlarged it to aan 11x17 and laminated it. Worked great, you could stick it right under the hood with magnets while troubleshooting the truck.
73m819
327
gainesville, ga.
when i got my ford f350, i had a circut just not gettig any juice, i checked and probed everywhere, it turned out to be a bad fuseable link, that showed no sign of being bad but on testing, it was dead
jumpmasterjim
NY/NJ
the fuse panel is under the dash left of steering wheel. Fusible links on passenger side of engine compartment and around solinoid on firewall.One of my 1008s' is having similar issue. I'll have to get the multi-meter out this weekend.
pitbull
Nova Scotia
I had the same problem with mine. It was a fuse. It wasn't blown but it wasn't healthy looking either.Here is a quote from another thread on which fuse it was.
"The row with 4 fuses in it, furthest right one ... 30 AMP. Yeah, my fuse doesn't stay in there 'naturally', so a little hotglue is working some magic with it.
I believe that row is the third row from the bottom. Bottom row being the single 28v fuse.
HTH,
-graham"
I hope this helps, Dustin
aja458
lehigh valley pa
re-fuse to lights
replaced the fuse-looked ok still nothing.
question on the alternators
do the alternators switch off and on while running.it seems like one will charge one battery then you hear a click and charges other battery. volt meter shows its doing that. is that supposed to happen? or is there something else going on?
ida34
36
Dexter, MI
RE: re-fuse to lights
That is probably your glow plugs going on and off. Even though the wait light goes out they still go on and off when you have first started up. This causes the volt meter to fluctuate and the click is probably the glow plug relay going on and off. Does it do it just after startup or all the time. If it is all the time you may have a problem with you glow plug system.
Uglyranger
Waverly Hall, Georgia
I lost all lights, turn signal, head, tail and stop.....Had an estra 3 lever light switch, plugged it in and everything worked.....only took me three days to figure it out :shock:
aja458
lehigh valley pa
lights at last
today armed with a test light and a partial clue, i finally got my lights to work.seems to make them work the switch needs to be on the blackout lights on position. thanks for the help in making me see the light.
