m1009 injector issue
THolzknecht
louisville,ky
I recently bought a m1009 with 13000 orignal miles and i have a few questions 1st is i think i have a bad injector front driver side its the only one that wetness around it and then the other day i had pure diesel in my drive way. i popped the hood whiles it was running and it was leaking well more like a constant drip where the fuel injector line is attached to the injector. next question does it need to be tightend or replaced. will the civilian 6.2 injector's work? not to mention the cucv keeps dying but it only dies when its in drive or reverse i have to put it in neutral while at a intersection and it idles weird aswell any help would be great guys
12vctd
Junction City KS
well let me explain first theres two things that could be leaking there the line to the injector or the injector itself. If its the line I would just simply retighten it slowly and see if it stops it if its the injector it might have a bad copper sealing washer but you could tighten it alittle as well
Barrman
1,686
Giddings, Texas
Don't go gorilla tight with it either. The line will crack if crushed. While using your 3/4" open end to tighten the injector hard line, make sure the injector isn't moving as well. If it is, loosen the hard line, tighten the injector up and then tighten the line up. Don't forget that the pair of return lines on each injector could also be the cause of the leak.
THolzknecht
louisville,ky
one other thing i for got to mention i used stp diesel injector treatment in it for some odd reason could it be the cause? some people have said it not good to use those fluids in some diesel engines?
