So after having issues with what seemed to be air in the fuel lines, I've replaced lines, filters, and lift pump. Each seemed to fix the issue for a couple days, and eventually turned into not starting at all. The injector pump began dripping fuel from everywhere, though, so now I have a new one. However, I seem to have messed up the timing on the pump... no start, dark smoke from the exhaust and some from the intake. I removed the pump by going through the hole for the oil fill, which was recommended to me as far easier, but I can't see any timing marks that way. So my question is, when replacing a pump this way, is it a crap shoot as to whether or not the pump matches up? If so I'm sorry I didn't just pull the timing cover off. It's aggravating having to go buy gaskets and such again...
