M1009 Intermittent wiper and horn failure
Trailgator
South Central Lower MI
‘84 M1009 The Wipers will be working fine then shut off, when attempt to turn back on they will not work, nor will the horn work, next day, horn works, turn on wipers they work fine, then problem repeats itself. I’ve tried connecting a separate ground from wiper motor with no joy.
Suggestions please...........
Thanks.
n8roro
IL
Could the fuse have poor contact with the fuse box? A frayed or crushed wire coming out of the steering column causing intermittent connection? You need new contacts inside the steering wheel column?
Trailgator
I’ve checked the fuse and it’s connection, it’s good &clean. I should have said that the wipers would work until I turned them off, then when I would try to turn them back on they would not work until setting at least overnight.
Thanks.
Jaywatch1009
Central KY
Thanks.
Trailgator, you ever track down the culprit? Having the same issues…
