RickTheEngineer
- 5
- 16
- Mount Laurel NJ
Hey all, I'm just finishing up putting on 4" lift springs in the front of my M1009 K5... My biggest question is do I need to correct my pinion angle? (The spring is symmetrical and doesn't have any shims on it, just as you'd find on any K5 lift kit for the front springs). I know the idea behind the driveshaft angles and all, but here is why I ask. The front driveshaft as many if you are familiar with are double cardian, so I'd imagine that the front pinion should point to the tcase? Only thing is that I heard shimming the front can cause drive line issues from messing up the caster? Or should I just leave it? Thanks y'all!
