JAD561
- 0
- 6
- BETHPAGE NY
I have seen many posts on no heat / heater core problems. Some users have refered to napa replacement cores. Does anyone have a part number ? I think i might need to replace mine. I pulled the thermostat and replaced it with the hockey puck type. Did this last week when the temp outside was 10 degrees. The gasket sealant was freezing as i applied it. Bolted everything up anyway. Had a little heat while parked, no heat while driving. I guess the engine heated up the frozen sealant because i sprung a leak after a few hours when the system was pressurized. Re-tightend the bolts. No more leaks, but now the heat blows cold all the time. Checked the cables under the dash. Everything is ok there. Noticed that the heater core hose to the engine was warm, the core hose to the rad was cold. Thinking i'm either air bound or the core is plugged. I will run it tomorrow with the rad cap off the see if we can bleed any air out, or i will replace the core. I don't want to take a chance on doing an engine cooling system flush. If the core is plugged, i don't want to possibly break something loose that could be holding the core together.
