Don't think it was according to my load tester, however I changed it out because it was smaller than the back so they were miss matched and the bracket was not sitting on it correctly, I will use it on my boat though, still puzzled how the glow plug relay could shut off the power to the ignition switch and engine
I still think it was a bad battery.
My M1009 acted the same way as your ride and had me buffaloed for days. I went through all the motions of checking everything electrical. I even disconnected and cleaned all the grounds and fuse holders with no joy.
The battery and its connections was the first thing and then again last thing I checked. The clue finally came to me when the battery wouldn't charge above 12 volts nor hold the charge overnight. The next day it would read 10 volts.
I brought it to NAPA, their load tester said FUBAR when my
el-cheepo home tester said it was good.
Hooked up the new "group 31 truck battery" they sold me and problem solved.
IMHO,
These CUCVs were well engineered back in their day but all their components must be "working together" as designed. If one part of the system is broken, bypassed, missing, or modified, it most likely will show up as a bigger issue down the line.
