Barrman
- 1,730
- 113
- Giddings, Texas
I have been reading for years on here about how weak the M1009 pintle hitch really is. I have put thousands of miles pulling supposedly too heavy for the truck M101 trailers with no issues and no bending of anything. Granted, I haven't tried pulling any 105's or yanking trees out of the ground either. I figured the guys on here talking about how weak they were just were abusing theirs or took the warnings in the manuals a bit too literal.
My fuel gauge has been reading about 1/4-1/2 tank when full and E when actually empty. Unless I hit a speed bump a bit too fast where it will read actual readings until I turn the key off. Then back to just half range again. I just drive 400 miles and put fuel in. Anyway, I finally got a new sender unit and went to install it today.
There are 12 bolts that have to be removed before the skid plate can be dropped according to the -20. 8 of those bolts directly hold the pintle hitch housing on. The attached picture shows the remains of all 8. All either broke off when I tried to loosen them or were so rust pitted they can not be used again.
Basically, I was fortunate my pintle didn't break loose from my frame/bumper. My driving style when pulling a trailer makes your grand mother driving to church on Sunday morning look like a speed demon. That is probably my only reason for not having broken anything yet. My advice is to put new bolts in place of the 8 age unknown ones in there if you are going to pull with the pintle.
Once I got the skid plate down, all 6 bolts came out with ease. I snapped off both strap threaded ends while pulling off the nut which holds down the rear wiring clamps. I didn't try the nuts actually holding the straps up because they looked rusted as well. I bolted the pintle back in with new fasteners and will wait for pay day before I buy new straps. Then I can take the pintle off again, drop the tank, put in the new sender and get everything back on again.
The -20 talks you through the fuel tank drop procedure very well. I spent about an hour getting to the point of being ready to drop it. Figure 3 hours start to finish if you are going to replace the sender. Also have a supply of 3/8" and 7/16" fasteners on hand so you can put good parts back in.
