I know this has been covered many times, but I'm looking for some details that I haven't been able to find with the search function.
I have all the guts of my m1009 tailgate swapped over to civvy K5 internals. Just finished the half ass job that the P/O set up, otherwise I would not have a functioning window. The window goes up and down well with a power drill. I ran a 10g wire from a 12v fuze block I put under the hood to the back of the truck. I bought a new window motor that bolts right up where it is supposed to. Also, i have the original civvy window wire harness in the tailgate as well. Then I hooked up a switch with a bunch of alligator jumper wires. The motor turns clockwise/counter clockwise with ease. However, when I hook it up to the window regulator cable, it doesn't have the power to move the window at all. Also, the jumper wires will get incredibly hot with only a few seconds of run time. The motor is brand new, and is perfectly good.
What wire gauges should I be using for this? is 10g enough from the power source? What sized wire should I be using for the harness/switch? The OEM harness has 14 gauge I think.
any help would be appreciated.
