REDWOLF
- 0
- 0
- Risingsun Maryland
The steel brake line that runs down the frame to the rear brakes sprung a leak right were it is clamped over the axel in the frame rail. just need to verify that the size is 1/4 inch so I can pick up a piece of line and get it fixed tomorrow. another real quick question does any one have a trick to getting the lines apart were the steel meets the rubber hose going down to the rear. I have sprayed it with PB blaster a couple time because it is pretty rusty. thanks
