m1009 Replaced the starter now won't shift
Alpha
Chattanooga, TN
I just replaced the starter in my m1009 with a gear reduction starter. it starts up real nice but it won't shift out of first now any ideas?
thanks
Ken_86gt
Williamsburg VA
I don't see any reason why the starter has anything to do with the shifting of the transmission?
I would troubleshoot the vacuum system first, any hoses pop off or leaks?
Alpha
Chattanooga, TN
nothing that seemed out of place i will take a look in the morning ( when there is light available), it sat a couple of weeks while waiting to acquire the starter then the bracket. but that is all that i have done to it...
thanks for the reply!
2deuce
147
portland, oregon
Check the vacuum hose where it connects at the transmission. If it got pulled off when you were under there with the starter, the transmission won't shift.
Alpha
Chattanooga, TN
climbed underneath and looked the hose is still connected to the brass colored thing (modulator i think) is there another spot it where it should be connected?
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
Pull the modulator out & use an Hand vacuum pump on it to see if it move if not replace it & get an fully adjustable one.
But it sound like some thing Moore than Vacuum how is the trans fluid look & smell.
Had some times an Th 400 govern stick or will have an effect on shift to.
If you Have time PM me & I give you my Ph number I talk you through to what is going on to
trouble shoot it.
Chris
Ken_86gt
Williamsburg VA
It should shift to second gear if push the pedal down, when the engine starts screaming, then it should shift to second even with a problem with the vacuum system. If it does not shift to second then you may have internal transmission issues.
Alpha
Chattanooga, TN
Thanks for the Info!:beer:
the tranny fluid looks good, and it will do the hard acceleration shift. I just had not been willing to push it that hard:shock:. I have bought a new modulator to put in, and will see if that solves it.
Warthog
230
OKC, OK
If you have checked the connection at the transmission and it will shift during acceleration, you need to check the vaccum hoses on top of the engine and on the Vacuum Valve on the injector pump.
The Tech Manual Troubleshooting section covers how to do this as well as many posts.
