2deuce
- 147
- 63
- portland, oregon
I have a antenna base brush cover with up arrows for the M1009 and 08. The rubber window gasket is in the way with the m009 arrow up. If I mount it with the M1008 arrow up it barely protects the antenna base. I hope this is right.
My antenna base is mounted just outside from the radio table. I have a large box of cables, the diagram says that the AN/VRC46 takes a cx4722, I have a bunch of CX4722a cables. Are they the same?
I also have a c2299 box. Can I use it to remote the headset and mic? and still have another mic and headset at the RT524? While this is only a display I would like to get it right.
What is used to keep the weather out of the antenna cable hole in the fiberglass top? silicone or was there a rubber plug with cable holes or something?
Where is the antenna whip fastened down?
