M1009 Snow plow 2011
Smokingman
Two Harbors MN
Blizzard 760LT(2011)
Plow Box B0761
Undercarriage B30089
Headlamp harness B62220
Joystick B62073
This set up will bolt right up to an M1009.It is the only set up I have found that will.I would like to know if any one has any other options for the M1009.The price at the local Blizzard dealer is $4240.40 out the door with tax(MSRP is in the 4400 range plus tax).
Do I have any other options for a NEW plow?
SPECIALTYLC
Washington
Just for your info. If the new style Blizzard mounts between the frame rails like the older style plows, there is a minor issue. The CUCV has extra brackets on the frame which makes them about 3/8 narrower than civi trucks. May need to trim the snow plow truck under carrage to fit properly.
ryan77
56
Cary IL
Check junk yards i saw 2 k5 blazer with plows sitting in the junk yard this weekend!!!
Danger Ranger
23
Roland, IA
Are you sure Meyers doesn't have anything? Seems they have plows for everything and anything...seen some weird setups before.
Just be sure to post pics...
Stroked66
19
Salamanca/ ny
Just finished installing a Western ultramount system on my M1009. Cost for the truck side was $1475. Just completed the wiring today and hope to test it out tomorrow after I installed my new glow plugs. I'll try to post pictures later this week. This was a kit set up right from Western with no modifications required.
