DREDnot
- 443
- 63
- Phoenix, AZ
One of the minor annoyances since I bought this truck has been the incorrect speedo reading.
I have stock axle ratios and 31 inch tires.
Its way fast. Checked it with phone/GPS and it was 10MPH fast at 25 and got worse. 19 off at 50(reading 69)
Did some searching on here and saw a lot of similar complaints. Most mentioning cable lubrication and casing damage/wear. Also talk about the "adapter" gearbox added at the Transfer case hookup.
Took that little guy off of there to see if its functional and whatnot.
After monkeying around with it for a bit, I came to the conclusion that it was overdriving the cable output...a lot...
Decided to hook the speedo cable back up without it.
GPS matched speedo perfectly now 25@25. 57 at 55.
Good cheap and easy fix just in time for holiday policing activities(speedtraps)
I'm not sure of the tooth counts/color on the drive gears as the housing didn't want to pop free of the t-case. The top of the square cable receptacle(driven gear) looked tanish/yellowish. So maybe its not correct(brown?)
Anyway, Its a nice thing to have working again.
