M1009 Speedometer Insanity
toxicroadkill
17
Danville il
Hello all, when I bought my m1009, it had 31" tires, and the speedometer was reasonably accurate. Now that it has 33's on it, the speedo is off of course..
Can anyone shed some light on what speedometer gear combo's the driven and drive gears need to be to get the speedo back to being reasonably accurate.
It has the original ratio adapter "777F1.3000" still attached.
my neighbor has one also, and also 33's and his speedo is correct.
both vehicles have the yellow 41 tooth driven gear and the same ratio adapter "777F1.3000"
from looking at his and mine, it looks like my drive gear is a 15 tooth, and his is a 18 tooth. it's very difficult to tell the colors of the drive gear by looking in the transfer case housing, so I'm not 100% sure if the drive gear tooth count is accurate. but that's what I "think" they are, but not 100% sure.
figured someone here has ran into the same issue, and knows the exact gear combo to use.
also, does anyone have a part number for the transfer case tailshaft housing gasket? planning on changing the drive gear, bushing and seal, and would prefer to use a gasket and not RTV if at all possible.
any help would be very much appreciated.
1,176
Moved to correct forum.
