First thing: I am dumb to normal vehicle electronics, especially this 12/24 volt system.
About the only thing I know is that the frame is the ground
When I bought my M1009 it started fine. I drove it around for awhile then just the other day I began to have starting problems. It turned over hard on a couple of starts and then, a week later I went out to start it up again and it would just barely turnover, not fast enough to start the engine. I tested the batteries and I was getting 11.2 volts off the rear battery and 12.5 off of the front battery. I Jumped it from the rear battery and it turned over hard once or twice and then turned over faster and started. I did this to get to and from work, since its the only vehicle I have. Now it won't even turn over, the only noise is the clunk of the solenoid. I checked the batteries again and they were the same. I disconnected the starter wire from the started and stuck I the meter on it. I recall getting about 23.5 volts there. With the vehicle turned off I was getting 24 volts between the positive terminal on the passenger alternator and a ground, and 12 on the driver's side alternator. Also I have been having an array of dash light/brake light problems - not sure if the related or not. The gen1 light was coming on when I started the vehicle but it would go off as soon as raised the engine RPM's... And I think the gen2 light was not working, because it didn't come on when the key was turned to "on" (before the starting problem).
I do not know what to do, i don't even know where to start!
