cptd
- 0
- 0
- Cibolo, TX
I have an M1009 with 16" rims and some nice coopers on the wheels.
I have 2 questions:
1. When at right lock I am getting some rubbing from the drivers side tire on a steering component, I think it is the pitman arm. I do not know what the offset is on the wheels and would like to inexpensively fix this.
Spacers?
New pitman arm?
Or is there some adjustment available that will fix this?
2. This leads to the second issue. Occasionally when driving slow (less than 10MPH, like a right turn with a yeild sign or into a store's parking lot), or from a stop when turning right the steering wheel will not come back to center eventhough the wheels do. Then about a block later it will violently correct itsself. Usually about the time I hit traffic speed. So far, because I know it is coming, it has not caused any real hazardous situations, but I know it will come.
Also it seems, only rarely, that the front end is in 4WD. I say that because I will occasionally get the sort of feedback from the front tires that you get when 4WD is engaged on dry rocky asphalt.
Anyone else with thess issues?
Any ideas on a fix?
I see these both as related issues, am I wrong?
I recently had the front end rebuilt, with a focus on the drivers side as the hubs were about to FAIL. I did not drive it before the fix as the vehicle arrived while I was still deployed. My wife had it fixed. She has not driven it since it has been fixed when these problems arise.
If pictures are needed, plese let me know what you want to see. I have searched the manuals and the forum and not found a fix, but I may not know the search terms to use.
Thanks,
CPTD
I have 2 questions:
Spacers?
New pitman arm?
Any ideas on a fix?
Thanks,
CPTD
