niferous
- 6
- 18
- Houston, TX
This is getting pretty frustrating. Ok my truck originally had a serious transmission leak and wouldn't move. Well it turned out I was missing my vacuum modulator and modulator valve. I just put both of them in and added transmission fluid. I get in the truck and it fires right up, try to drop it in gear and nothing happens. Normally you feel a clunk of the transmission ****ting into reverse or drive but for me there was nothing. So checked the fluid and it's below the add line but also the transmission is cold. I put 3 quarts in it before trying this. Also I should point out that the transfer case is in 4 Hi. The reason for this is because it was in neutral when we towed it home from Redstone and I can't get it moving to shift it into 2 Hi. As it is right now it doesn't want to shift back down into Neutral on the transfer case. The truck also rolls forward if you push it but does not roll backwards.
So I'm stumped here. It has trans fluid as well as a vacuum modulator (O'Reilly VM324), and a modulator valve I got today from a transmission parts house. Also I got underneath it with the truck not running and had my girlfriend shift the truck and it is ****ing down at the transmission. As in the rods are moving and turning when it's taken out of park and put into gear.
Any help or advice is appreciated. Hopefully it's just something I am doing wrong.
