OD Heavy Hauler
- 0
- 0
- Halifax Co. N.C.
Looked at a 1009 to buy but having second thoughts after seeing IP leaking badly. Want to know if that leak would cause a hard starting issue (drawing air in system). It started and ran for about 2 seconds and died out. After cranking 2-3 mores times it fired up. Thats when I saw the fuel leak. Truck cranks on cue it seems after initial slow start and warmed up. Then after its warmed up the IP leak slows down. I'm thinking it's going to need a new IP. What gives?
