tgtaylor64
- 4
- 18
- Florence, SC
My M1009 will not down shift under load. Vacuum lines replaced and checked the resistance of the accelerator shift switch (goes from infinity to 0 ohms at full throttle). I now want to check/replace the solenoid on the drivers side of the transmission. Do you just remove the orange wire and screw is out? Is this an expensive part? Tips?
