Ok I spent the last 3 days trying to get the floor finished on my M1009.
I cut out the remaining bad spots in the floor and welded in some new metal.
Once I had it welded in and used a wire wheel to remove the temporary primer over all areas that had rust at one point.
I also cleaned up some minor rust damage on the inside of the passenger side fender.
I then put down some acid that converts the rust and cleaned it off. I then put down POR-15 on all areas that had rust at one point on the floor.
Once the POR-15 was tacky I painted a Rustoleum Primer over it.
BTW I had an incident with the POR-15. When I was under the truck touching up part of the fender with POR-15 I accidentally rolled it the pan of it and didn't realize it.
When I was done I noticed my hair on my head was stuck together and my neck and right arm were black.
2 days of scrubbing with acetone and I got most of it off. Though my hair is still glued together in some places.
Well back to the truck.
I finished spraying the bare metal with Rustoleum Primer and the let it dry.
I then cleaned out the entire interior with soap and water. Though the sugar sand still seems to creep back up on me.
Last I put seam sealer down along all the weld beads. That stuff is messy!
Hopefully this coming weekend I can get the bedliner down.
