M1009 water leak
alm0263
denton, Texas
My 84 m1009 has a leaky water pump. Anyone know the gasket part number? Or an easier quick fix?
It's leaking on the passenger side, out of the seal between the pump and block.
319
Lieutenant
57
Michigan
Should be the same as a stock 6.2L
Try your local auto parts stores
papercu
31
Baxley, Ga.
If the water pump gasket is leaking, this is a good time to get a new water pump, hose, belts and change the antifreeze. Only thing you don't want to mess with is the thermostat, if there is no problem with it. Wayne
