M1009 weak floor?
galeo7171
Cumming, Ga
I noticed that my passenger side floor has cracked. Basically at all four points where the seat mounts, anyone else have this problem? I had to jack up the floor, re-weld the cracked seams, then weld a panel over that, then I'm having line-x sprayed down over that. I'm guessing this will be strong enough now??
AJMBLAZER
Paducah, KY
RE: Re: RE: M1009 weak floor?
Okay...let's not say rust...let's say corrosion. All metal does it with age and these trucks' floorboards are definitely a weak spot.
It's a common problem on higher mileage civilian trucks as the metal has become brittle and then gets a bit more abused and CRACK goes the floorboards.
galeo7171
Cumming, Ga
Re: RE: Re: RE: M1009 weak floor?
Will having line-x put down over the entire floor of the blazer strengthen it?
AJMBLAZER
Paducah, KY
RE: Re: RE: Re: RE: M1009 weak floor?
...and make sure it's sealed up good so moisture can't continue the problem or restart it.
galeo7171
Cumming, Ga
Re: RE: Re: RE: Re: RE: M1009 weak floor?
CCATLETT1984 said:
no, have it welded up, then do the spray-in liner.
I jacked the floor back up, welded the broken seams, then welded patch panels over that. I'm having the line-x sprayed on, then I'm going underneath the truck to seal up whats under there. Although the underneath of the truck looks brand new, like it had a black rust proofing applied to it
K45
Statesville NC
I will say I notice that the seat mount holes are a little close togethor. It seems the weight does not get to distribute the weight well. For my 79 blazer I cut some stripes of 1/8" thich steel and drilled out the seat mounts holes and put the seat on it then the floor. Helps to spread the weight out. Could help yall out and easy to do.
