chisky19
- 0
- 0
- Huntington Beach, California
Ive had my m1009 for about half a year now with absolutely no problems. Last week I did a Dana 60 (with a locker
) and 14 bolt axle swap, 4 inch lift, shackle flip, with 37 hmmwv wheels and tires! Well since last week I have driven the truck about 50 miles between three days and then I let it sit for 3 days. Today I went to go drive it to my shop to do a crossover steering swap and could not get it started except for about 5 seconds and then it bogged out and shut off. My fuel gage is at 1/4 of a tank so I know I am not out of fuel as my fuel gage has worked normal since I first got the truck. I primed the fuel lines, absolutely no air in the lines, I pulled the pink wire off of the IP and it made the clicking noise. I pulled the fuel filter (full of fuel) and unscrewed the plastic + sign and had fuel coming out of the hose when I turned it over. Theres no fuel leaks anywhere. I pulled the glow plugs and they all seem to be working. Truck turns over and sounds like it wants to start but it just wont fire. I tried so many different things that I finally wore my battery down and drained it (its trickle charging right now). I have absolutely no idea what to try next. Everybody I have talked to said I probably ran it out of gas so i went to the station and got 5 gal and poured it in and reprimed the truck. No luck. I then checked all of the fuses just in case and no fuses were blown. Let me know your thoughts about what I can try next cause I want to get this thing back on the road! Thank you so much for the help!
I just want to
![Wink ;-) ;-)](https://www.steelsoldiers.com/images/smilies/icon_wink.gif)
I just want to
![Git-r-done :grd: :grd:](https://www.steelsoldiers.com/images/smilies/grd.gif)
