m1009 will not start
31gooseman
ararat, Virginia
Had a run away starter. Rebuilt starter and it still run away. Found Doghead mod and did that. Had problems replacing key switch cause previous owner used roll pin the hold key lock in place instead of the screw. Ended up replacing steering column and now I get nothing when I turn the key. All lights work, and have traced power(red wire) all the way to the steering column, but when I plug it into the ignition port on column nothing happens when I turn key. Any help would be so greatly appreaciated.
joshuak
214
Slower shore, DE
Greetings gooseman, welcome aboard.
Loose connections at the 12v termination block proved to be the culprit when I had a no start condition with similar characteristics (functioning lights, 24v present at starter relay, etc.). Probably not your case, but worth a check.
I'd start a thread in CUCV forum or request a mod to move this one and for sure folks can help get you going.
While your in that forum check out the CUCV Helpful threads sticky, this one in particular deals with burned fusible links after starter run on.
Good luck, electrical gremlins are no fun to chase IMO.
