placek59
- 12
- 3
- SE Nebraska
Hello All,
I got an '84 M1009 a few months ago and have been tinkering on it and trying to make it more reliable. It had a fuel leak from the lift pump to the fuel filter. I cut that hard line and used fuel hose to replace the section the 16" ~ish section from where the line was leaking to the fuel filter. After doing that, I have been having intermediate glow plug issues.
Sometimes I get no wait light at all, most of the time it would stay on forever (I turned the key off after 30 seconds or so), and once it worked as it should have so we got to go for a drive last Saturday and fueled up! Might have put 15 miles on it cruising around the countryside.
My questions are:
1. How do I remove the glow plug card under the dash? I removed the black cover and tried to pull it out gently, but didn't want to force it and possibly break some brittle old circuit board. They should just pull straight out, correct? I wanted to clean the contacts and inspect the board.
2. I suspect the relay on the firewall is shot as I was not getting any voltage out of the bottom post while the key is turned on and have no continuity between any of the terminals or posts. I have 12v to the top large post and get 12v to the upper small post. I bought a new relay but haven't installed it yet. There is a mystery blue wire going from the resistor bank to the top post and then from the top post into the fuse box under the dash. It is just plugged into a fuse location. Any idea what the thought behind that may be? See the pictures for a better idea.
3. I found a green wire not connected to anything hanging by the driver's side alternator. Any idea where it might go? I don't see anything obvious. It looks like a glow plug wire but all 4 plugs have wires on them. I did not check it for voltage or any continuity to ground or anything else. I didn't see any green wire on the charging system diagram. Again, see pictures.
I hope to get out to work on it some this weekend and do some more cleaning of grounds and chase some gremlins. I have the glow plug wiring schematic printed out to use too.
Thanks,
KP
My questions are:
Thanks,
KP
