M1009 won’t shut off
82ABNMP
53
Winston Salem NC
Yes, I’ve searched the site, and did look through my TM.
I have had the truck for several months and it didn’t do it at first but has gotten progressively worse. Started to stay running for 10 seconds then 30 then maybe a minute to shut off. Now stays running until I pinch the fuel return line.
I did change the ignition lock cylinder on the column.
checked the ground wire from the ignition switch.
The pink wire on the injection pump has 12v with the key on and 0 with the key off.
If I pull the pink wire while running…no effect. Stays running.
Pulled the top of the injection pump and cleaned the fuel shut off solenoid. No effect.
What am I missing?
Thanks David
Guyfang
23,347
Burgkunstadt, Germany
I am no truck guy, but if this was a generator set, I would say you need to clean out the dirt or crud blocking open the solenoid. Any solenoid that will not close when power is turned off can only stay open due to being prevented from closing. Blockage or bad solenoid.
82ABNMP
53
Winston Salem NC
Thanks. I did take out the solenoid and clean it throughly. And it looked really clean before. The plunger and barrel are clean.
could the solenoid itself be bad?
thanks, David
82ABNMP
53
Winston Salem NC
…just trying to get an idea if it’s the ignition switch or the IP fuel shut off.
with the key on I have 12v to the pink IP wire
with the key off I have 0v to the pink IP wire
so this would suggest it’s NOT the ignition…correct?
Keith_J
1,317
Schertz TX
The solenoid is ETR, energized to run. Which is to say a spring in the solenoid closes the metering valve when the current to the solenoid is stopped.
I would say the solenoid, an electromagnet, is either dirty, corroded or in need of replacement. There was a design change in the 1980s to prevent magnetic wear particles from causing this failure. I would recommend a pump overhaul service. You could replace the solenoid, using Badger Diesel for parts. But you could have transfer pump or cam ring wear.
Guyfang
23,347
A shade tree way to "Kinda" test the solenoid is to use a wire to go to the terminal on the solenoid, from the battery. Hold your hand on the solenoid and then connect the wire. Do you feel anything? Do you hear anything? Repeat a few times. SOMETIMES you can. Also, take the pink wire off. Crank the engine over. If it starts, the solenoid is stuck open.
Barrman
1,725
Giddings, Texas
If you pull the pink wire and it stays running, then the trouble is not on the truck side of things. A rebuilt pump did the same thing to me when I installed it a few years ago. I put another solenoid in and all has been well ever since. Just pulling the top cover of the IP and swapping the solenoid is easy.
To turn it off in your current situation is also easy. Us a pair of pliers and squeeze the return hose coming out of the IP. The engine will turn off once pressure builds.
nyoffroad
682
Rochester NY
Buy your replies I am assuming the problem is at the pump if the ignition key is shutting off the power to the pink IP wire?
Good idea’s I’ll try and test the solenoid.
For sure the problem is on the fuel side NOT the ignition side. I've never done it but I remember reading where a person can put the injector pump cover back on wrong and block the solenoid valve open thus it won't shut off. I don't think thats your problem, just tossing it out there.
82ABNMP
53
Winston Salem NC
Thanks all, I do think it’s the solenoid. The truck will start without the IP pink wire attached. So it’s stuck open.
I did take it apart and the barrel and shaft we spotless. Probably the switch itself. I have a new one on the way.
Appreciate all the help.
David
