M101 Dimensions, or, will it fit in a M105
FMJ
37
Las Cruces, NM
I have 2 trailers to pick up in Santa Fe, 105&101, I'd rather not take the Deuce. Will the M101 fit in the bed of the M105? I did a search for dimensions/specs for the 101 but came up dry...
Or, if someone could measure the width of their M101, at the widest point (outside edge of tires, or fenders) that would help out alot.
Thanks,
Ed
CGarbee
577
Raleigh, NC
I have photos of both of my M101's on my website including shots of the weight and dimension dataplates that may be used to see the width, etc...
73.5" is what is given for the outside to outside measurment for the width of the body, total length with drawbar down is 147", length with drawbar up is 101"
See:
http://www.garbee.net/~cabell/photos9.htm
or see:
http://www.garbee.net/~cabell/photos16.htm
I don't have photos of either my M104's or M105's dataplates to reference from work so I can't answer that part for you...
Good luck
FMJ
37
Las Cruces, NM
Thanks, I have "several" :roll: M105's at home and a tape measure.......so the 101 data is what I needed, Thanks!
FMJ
37
Las Cruces, NM
Awesome thanks. Do you think I could back the 105 up to a loading ramp, set the parking brake, then back the 101 into the 105 from a loading ramp?
The fenders may prove a problem in the 105, I had GL load the 101 with a fork lift.
neilhendrix
Reidsville N.C.
Loading ramp should work BUT be sure to put the REAR landing leg down. The weight of the 101 going into the 105 will stand the 105 straight up. Don`t forget to put the landing leg bak up. Good luck,, I`d probably forget it
