M101 underbed spare mount?
papakb
1,184
San Jose, Ca
Has anyone on the list made or seen a spare tire rack that would mount under the rear of the bed on a 101 trailer? I'd rather mount it there than add the weight to the tongue with a front mounted spare. It means the rear landing leg would have to be removable but I believe this is a better place to put a spare.
I have an M996A1 ambulance and so I can't mount a spare on the back of it and think the trailer bed is the only solution.
Thanks,
Kurt
deucebigalo
South River, NJ
I too have wondered the same thing, I never actually tried doing it, but I have gotten under the trailer and looked at positioning a spare behind the axle, but it appeared to be too samll of an area to fit it.
rosco
Delta Junction, Alaska
The rear landing leg is there for a reason - remove it, plus the weight of the tire, and the trailer won't be very stable, when parked, especially when somebody tries to crawl in the back!. They tip over backwards. The tongue is the place for it.
Lee
Nick
Near Daytona Beach, Florida
Also depends on if you want to use it for dumping or not. If you dont, you might be able to use the cable style spare mounting, towards the front of the axle, near the frame pivot. Theres a very long thread on using one of the spare tires cables from a pick up truck found at a junk yard.
2cents, just put it on the tongue. Looks better, easier access, better for towing with the extra tongue weight
Nick
