M1010 12 volt conversion
Looking for some advice/help converting my m1010 to 12 volt charging system. My duvac went haywire overcharging the front battery. Already sourced leece Neville 12 volt alternator . Need some help with what wires to keep . Can't find wiring diagram anywhere I look. Thanks in advance.
Sent from my SM-G960U1 using Tapatalk
TechnoWeenie
1,669
Nova Laboratories, WA
Do you want to redo the entire system, or just the front battery?
Quite a few things require that 24V on an M1010.
Have you seen the Plan B thread?
TechnoWeenie
1,669
No A/C either?
Ehh... well... Follow https://www.thetruckstop.us/forum/files/nn10.pdf as a start.. You'll obviously have to remove one of the alternators or at the very least remove the belt... The M1010 uses 2 -24V alternators, and not 2 -12V alternators like the other CUCVs, but you already know that ;)
Look in the Plan B thread for information on how to disable/remove the DUVAC..
