ozarkphoneman
- 0
- 1
- Joplin Mo
Hello from SW Missouri! I am a new member to Steel Soldiers and a owner of a M1010. The truck has a charging issues. It does not charge the front battery. Someone has strapped diodes (tiny) on the front of the blue box one of which is burned in half. At idle I have 26 volts in series, 14 volts on the rear battery and the front battery (after charging) has 12 volts. Is it time to convert to a 12 volt system? I have considered keeping the 24VDC system to run radios/cameras but if the blue box is the weak link..... Any advice is appreciated.
