choll
- 5
- 18
- Las Vegas,NV
I have a pickup that has all the components of the 1010 ambulance. Two 28 volt regulators, A/C compressor, locker in front diff. I am having an issue with the battery charging, it not, 2 new batteries rebuilt alts still no charging. I have 25 volts coming off the bottom alt, nothing coming off the top. I did get the alt checked again it is putting out 28 volts at 105 amps on the bench. The wire that attatches to the output post does not have 24 volts going in, I visually checked the fusiable links they look ok. Do I have a bad voltage on the drivers side, blue box. If that is it I found a new one but the guy wants $500 for it. I thought it might be easier to convert to 12 volts.
I do have the conversion for the blazer as I converted mine. I also have a spare 12vot starter. Does anyone have the instructions on how to convert this system.
Thanks,
Chuck
Thanks,
Chuck
