panzerwillie
- 123
- 43
- miami florida
Well after 6 month is finally running, took a stock M1010 that was converter to 12 V and put a 96 6.5 turbo that i rebuild with new Heads and install a 4911 IP and new injectors had the 4L80E rebuild with new TQ conveter and install a new US shift optishift auxiliry oil cooler and tranny cooler will be installing a cab under the dash a/c and 3.73 gears next week or 2 will update as i do it, also made the down pipe to go outside the frame and was brougth back in under the body came out good had the local muffler shop do it from the down pipe back using a NAPA diesel muffler for now here are some pictures
