softboyled
- 0
- 1
- Portland, OR
Hi,
I've recently acquired an m1010 and thought I'd tackle the inop box heater first...
I've discovered that the fuel pump on the left fender that feeds the box heater (and the arctic heater if installed) makes some rather nasty clunky noises when powered. As I received it, the cutoff switch was zip tied to the fuel lines (oriented horizontally), so the pump wasn't seeing any power. When I mounted the switch in its proper bracket and turned on the heater, the clunking began in earnest. It's clear that some PO simply disabled the pump with the zip tie trick. The most recent PO claims no knowledge of the heater status, so no help there.
In addition to the awful noise, I removed the cap on the tee just aft of the pump and there is no fuel produced when the pump is activated.
I am assuming that the pump is bad. What's the best source for finding a replacement?
Thanks,
Greg
Thanks,
Greg
