Sbblake
- 0
- 0
- Beaumont texas
Recently purchased a M101A1 trailer to tow behind my 1946 Dodge Power Wagon. Paid to much for the trailer ($1300) but have not been able to find one close enough (Beaumont, TX) where shipping put the total price out of reach ($1800-$2500 with shipping). Preferred the M101A1 as the tires and BUDD rims match my power wagon. Now that I have bought one I expect 2 or 3 to pop up next door... Murphy's Law...
Upon further inspection of the trailer there is rot on the horizontal cross member that is located directly in front of the wheel well and there is a liberal amount of corrosion on the front panel where it meets the bed (all other cross members and trailer frame members appear to be in good condition). I suspect that the floor will need to be replaced. Recently quoted $450 to get the trailer completely sandblasted to see what I am up against.
Would appreciate members input on the following:
1) Is the sandblasting cost of $450 reasonable for South East Texas area? Seems high to where I have done sandblasting work before (Alberta, Canada).
2) Has anyone replaced the entire floor? If so what did you replace it with and estimated material cost?
3) I am considering replacing the front fixed panel with a tailgate. I found a new tailgate for approx$150 (including shipping). Has anyone attempted this upgrade?
4) If I am going to replace the floor I was also considering taking 1.5" out of each wheel well. This would give me 48" between wheel wells allowing for full sheet of plywood to be loaded into the bed. Have any members made this change?
Thank you for your time and consideration.
Regards,
Scott
Regards,
Scott
