M101A1 generator trailer ?
dan00d
Belgrade, Mt
Hello all,
I have been looking for a M101 to pull behind my jeep and I cam across what looks to be an M101A1 that had a generator mounted in the box. the trailer has a few dings and dents but no rust and is missing the lights. Now here is the good part, the fuel tank is present and in great shape. Could anyone give me an idea of what this is worth or what the data plate should read, it is pretty faded and scratched up.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
I'm not sure what you might have run across...I'm sure someone else will chime in soon enough. Pictures would greatly help. But, as far as I know, the M101 should not have had any fuel tanks mounted on it. The generators have their own tanks, and it's very odd to say the least to see a military mounted aux tank on a 101.
Tanner
11
Raleigh, NC
dan00d
Belgrade, Mt
Thanks guys I believe it is the M101A1 that was converted in the field then. It has several holes in the bed that I figured were to mount the generator. The owner is asking $900.00. Is this a reasonable price ? I figure I could either keep the tank and have an extra fuel source or drop the tank and offer it here. I am just not sure of what the value of this trailer is. I told the owner that I have not seen an M101A with this tank option and that I would have to do some research before I made an offer.
Tanner
11
Raleigh, NC
Price may be good for your area, but I have seen nice complete (all lights & wiring working, etc.) trailers go for well less than this. Not an insult to the seller, but location could make a difference on pricing. I've seen them range in price from $250 to $1250, depending on condition.
Question: what tires/wheels are on this trailer? If it's a M101A1, then it MIGHT have 5 lug Budd rims from an Dodge M37. Or it may be a later version with modified with the M880 wheels.
Pictures available?
'Tanner'
1,808
There were several M101 based PU units produced. Some with a single 3KW set, some with dual 3KW sets and a 101 with a single 5KW set. Some of these did use a gas tank very similar to the M37. TM 5-6115-365-15 is the TM you seek for clarification. Also check the tongue on both sides to see if you see a PU number data plate (PU-619) or the like.
