M101A2 bearings quite warm
shotty
56
Northern VA :(
Today I took a fully loaded M101A2 for a 15 mile round trip, fully loaded (2250 lbs) and when I got back I checked the hubs as I had just installed new bearings. They were quite warm. Not too hot to hold on to but almost. In my experience, this is not a good sign. I went home and double checked and I had the axle nuts only finger tight, after torquing and backing odd. I can feel and hear just the slightest amount of play in the hub, so I know it's not too tight. This seems like perhaps this just the way its going to be with a 1500lb trailer loaded with 2250 lbs of stuff?
truck1
10
San Anselmo,CA.
I've loaded mine with 1 1/2 T many times and the bearings get warmer but not too hot to touch. Did you grease them thoroughly? I've always greased bearings by hand, but bought a pressure cup style grease kit. You know they are saturated after using. There is a TM available on line, and here on SS that describes servicing the M101 series with nut torque values and such. Sounds like dry or loose bearings to me.
shotty
56
Northern VA :(
They are definitely packed with grease, and there is only the slightest amount of play. To remove the play I might have to go past finger tight and that feels like it might be too tight.
DeadParrot
47
oklahoma city, ok
My M101A1 runs warmer empty than my M1101 runs loaded. But it is still in the just warm category, not hot to touch.
Might feel the brake drums and make sure that you don't have heat from brakes warming up the hubs. If the park brakes are tight or you had a lot of surge brake engagement, could be where the heat came from.
