M101A2 Padeye
niferous
Houston, TX
Are these things one piece? Mine broke and I'm not sure if the threads are part of the padeye or if they thread into it. If it is a solid piece where do I get a replacement?
niferous
Houston, TX
Sorry forgot to attach it and also to better describe it. It's been a hectic night. It's what is on the front of the trailer and the bolt passes through to secure the trailer and keeps it from dumping.
KsM715
142
St George Ks
I believe it is bolted on from the backside (bolt threads into it) I have the TM for that trailer let me see if I can find it.
Edit: Scratch that, according to the tm it has threads on the padeye and a nut holds it to the frame.
1,177
Why not drill it out and re-tap it?
jimbob1111
winder/georgia
Hi,
Two of my trailers have a pad eye welded back on. Grind everything down to clean metal, reassemble and weld it back on. I broke one putting it back on after drilling the hole a little bigger to make it easier to get the pin back in. The other one welded on is a previous military repair. I have no idea how long ago it was done, it's a M101A1 and it has been that way a LONG time & held up fine.
HMFG
