M101A2 tires
Iron Bender
WA
Here is my M101A2 trailer with 315/75R16 tires mounted on 16x8 wheels with 4.5" of backspacing:
They fit just fine. You'll have no problem with even smaller tires.
papakb
1,185
San Jose, Ca
I ran HMMWV 37" HMMWV wheels and tires on my A2 for several years and all I did was put a 1/4" spacer plate behind them. Never had any issues with the tires rubbing the wheelwells even when fully loaded. The nice thing about the HMMWV wheels and tires is they're plentiful and cheap.
Kurt
KG6KMJ
Orionspath
Northern Virginia
M101A2 Tires Rims Applicability
What was the 1/4 in Back plate used for? To move the rim away from body/leaf springs? Where can I get 2 of the back plates? Really want to move from 9” tires to Hmmvee milSpec tires...what can I expect to pay for 90% rims and tires?k
Kurt
KG6KMJ
Coug
4,340
Olympia/WA
Yeah, to move the tire out just a little. Sometimes they rub a little bit on the parking brake cable is my understanding, this just moves them out a little bit.
I just paid like $17 for a pair of 1/2 inch spacer plates on Amazon. Looking at the studs that's probably the absolute thickest you can do without either doing longer studs or 2" spacer/adapter with their own set of lug studs.
I'm still looking for a local set myself, there's a guy about 150 miles away selling some used HMMWV tires and rims on craigslist for $100 each. Anywhere from $75 to $200 seems to be the going rates depending on age and wear.
